Samsung Tablet choices/recommendations?
Started by netn00b, May 13, 2013, 08:31:10
netn00b
Hi all
considering a tablet purchase for the flexibility of using it at home and other places.  plus my desktop pc is very old and out of date.
not into apple and wont pay the silly money for an iPad.
heard the samsungs are good ?  a friend was going to buy one at the weekend so waiting to see if they did and then hopefully get a play on it.
would want the biggest screen possible so the 10.1" would make sense.
anyone got one or recommend a different make/model ?
ta
Just to throw a spanner in the works, have you considered the Nexus 10 that Samsung make for Google http://www.samsung.com/us/mobile/galaxy-tab/GT-P8110HAEXAR, it has possibly the best display resolution available on a tablet?
netn00b
#2
only just started to look Glenn so apart from an iPad anything is in the frame as a possible  :)
what are the key criteria to look for when buying one ?  ie screen resolution ? memory ? battery life ? processor type/speed (dual/quad core) ?
wondering what to really concentrate on and what aspects to compromise on......i assume they all support WiFi and mobile data 3G internet connection?
oh and another question : what is the difference between a samsung galaxy Note and Tab ?
another question : apart form Samsung any other recommended manufacturers to consider ?
ty
Quote from: netn00b on May 13, 2013, 12:54:31
what are the key criteria to look for when buying one ?  ie screen resolution ? memory ? battery life ? processor type/speed (dual/quad core) ? I think it would depend on the budget and what you want to use the device for
wondering what to really concentrate on and what aspects to compromise on......i assume they all support WiFi and mobile data 3G internet connection? All will support WIFI, some will support 3G
oh and another question : what is the difference between a samsung galaxy Note and Tab ? The Note is a large phone, the Tab is a tablet with no native phone connectivity
another question : apart form Samsung any other recommended manufacturers to consider ? take a look here http://www.laptopsdirect.co.uk/ct/tablet-pcs-and-e-readers/tablet-pcs you can select the spec you want, then see what is available
ty
netn00b
thanks  :thumb:
so the galaxy 10.1 inch Note is a phone as well as a tablet for net use ?
netn00b
ohhhh thats good.
umm as for use.....browsing, e mail, some games, some movies, music
netn00b
whats the kindle fire hd like ? anyone know or got one ?
Only had a brief play but for the price it's functional as a browser,email device not a patch on the iPad which I compare it  in terms of build quality,screen resolution and performance. Like most things in life you get what you paid for.
