First post from phone
Started by Ted, Nov 04, 2010, 11:09:33
Ted
As above, never done it before. Just thought I'd see if it would work for future reference. :)
Ted
Ted
Quote from: Ted on Nov 04, 2010, 11:09:33
Ooo! it worked  ;D
Ted
Congratulations, Ted. Unlike Simon, you didn't make a single spelling or smiley mistake.  :evil:
Ted
Quote from: Rik on Nov 04, 2010, 11:16:08
HaHa! Been meaning to try it since all the BT outages, just for information really. You know, when you sit here and think "is it just me"  :dunno:
It was pretty easy really and surprisingly quick. I'm using a Blackberry 8700g with upgraded firmware (of course) and Opera mini, no contract, just PAYG.
Ted
If you use the wap interface, Ted, it won't consume so much data.  Just add ;wap2 to the end of the URL.  :)
Ted
Quote from: Simon on Nov 04, 2010, 11:28:02
Thanks, Simon. I borrowed this http://www.idnetters.co.uk/forums/index.php?wap2 from the outages thread.
Sorry to be thick but can you use the ;wap2 at the end of all urls, would it be http://www.google.com;wap2  ?
Ted
It depends whether the site supports wap, I believe, Ted.
Ted
Quote from: Rik on Nov 04, 2010, 11:43:15
And you know it supports wap... because?
Ted
What Rik said, but usually no.  I have the unread posts link bookmarked, and enter the forum that way:
http://www.idnetters.co.uk/forums/index.php?action=unread;wap2
Ted
Ok Simon, Thanks. I don't plan on doing too much on the phone, but good to have an emergency backup.  :thumb:
Ted
With some sites, you can use m. instead of www. to get their mobile interface, eg, m.crackberry.com or m.marksandspencer.com.
didn't get it on my phone. ;D
Google use to (may still) automatically use their servers as a proxy to give you a converted mobile version of every site. I cannot remember how to set it up though. It may be automatic when it detects what browser you are using to search google.. However I tend to prefer the HTML versions as the wap ones are horrid.
Quote from: Rik on Nov 04, 2010, 18:03:03
Especially the forum. :)
Oy! Your suppose to promote the forum. ;)
(Good to see you don't promote things that don't work too well. Not that Wap does not work, it's just most phones are more advanced now. It will be a lifesaver for some though, so bad looks aside, it's still useful!)
I use the wap interface here all the time.  It's plain, but I wouldn't say it's horrible, and it saves all that pinching and zooming.  The only time I go into the full site on my phone, is if I need to edit a post.
