Email connection
Started by wkb21, Aug 12, 2008, 13:50:48
wkb21
My idnet.com email connection has been dropping out regularly recently, then restoring again.  Is there a current problem?
KB
None that I know of. Are you talking about the webmail interface, or access via a client? If the latter, which client and how is the mailbox set up, ie POP or IMAP? What AV software are you using?
wkb21
Webmail with POP.  Don't know what AV is - - .
You're using both the webmail and POP interfaces? Are both dropping out, and if so, exactly what is happening, what error messages are you getting?
AV - Anti Virus.
wkb21
POP3.idnet.com with Outlook Express.  AntiVirus software is AVG.
Are you getting an error message. We had a case recently where AVG was having an issue with its proxy server.
wkb21
I'll have to check next time I lose connection.
Will report back.
Thanks.
KB
NP. :)
If you are able to access it during support hours (08:00 - 18:30), give them a call when the problem is present and they can look at what's happening at their end in real time.
Quote from: wkb21 on Aug 12, 2008, 14:04:08
Have you considered upgrading to Windows Live Mail, it is still free and far better than OE.
I use it with AVG, no problems at all. ;)
