Backing up IE
Started by stevelondon, Oct 30, 2006, 22:14:06
stevelondon
Does anyone know an easy way to back up IE6 favourites etc to transfer to another pc ive done Outlook Express etc ive found an extension for FireFox so thats done any suggestions  thanks in advance.
File menu, Import and Export, run the wizard.
edit:
You don't need an add-on for Firefox- from Manage Bookmarks, File Menu, export....
stevelondon
Thanks Bill it was blatently in front of me wasn't it lol  ::) thanks yeah i saw the one for firefox but the extension FEBE backs the whole firefox profile up.
The import/export on the browsers (Opera has it too) comes in very useful to transfer a favourites list from one browser to another- they're only HTML files so they all accept each others files.
With an occasional error... but a lot easier than doing it the hard way!
BassoProfundo
Better still, if you're using just IE and FF, go get Roboform. That way, passcards and bookmarks (doesn't use either IE Favourites, or FF Bookmark mechanisms) are shared between the two apps; all passcards/bookmarks you define are available to both. Brilliant little program.
Scott
For Firefox 1.5.0.7
File >> Import >> Internet Explorer...select preferred characteristics to pull in...FF will do the rest.
For IE7
File >> Import & Export >> Next >> Import Favourites/Coookies/Feeds (WHY three different options ! Terrible interface !)...you'll then be prompted for the location of the Faves/Cookies/Feeds you've already exported from FF.
GL & HTH
S
Member of the IDNet Mafia
zimmerframe
I use Outback, which also backs up IE settings too. http://ajsystems.com/obp.html
If The World Didnt Suck, We'd all Fall Off
Quote from: stevelondon on Oct 30, 2006, 22:14:06
Files and Settings transfer wizard is another route, it takes over a lot more, especially easy if the two machines are networked.
