Windows XP SP3 is RTM!
Started by Sebby, Apr 22, 2008, 11:14:33
I've been waiting for SP3 for a while (primarily because I want to format, so I want to slipstream and avoid all those Windows updates!).
Yesterday, it was released to manufacturing. It will be released to the public on 29 April.
More on The Register. :)
I don't foresee any trouble with this service pack, as it really is just a service pack this time.
It's a Microsoft service pack. That's an entirely different class of creature. :)
:hehe:
I'll happily try it as soon as it's released next week, so I'll let you know. :P
It had better not bugger up my new machine!
somanyholes
http://blogs.zdnet.com/hardware/?p=1686
so june will be fun time. It should't be as bad as when sp2 rolled out, the main reasons for the issues with that where due to the windows firewall being turned on, which should have been done on the original build, and would have saved a lot of time and money.
Indeed. SP2 was a major update, whereas this is really just a collection of patches.
Colin Burns
Quote from: Rik on Apr 22, 2008, 11:17:49
i thought they were suicide packs and if you install them your PC looks for the closest bridge
D-Dan
I had SP3 RC2 installed. That's why I had to do a full re-install from scratch. I'm wary of this one :(
Usually an early adopter - but it's far too soon after getting my system stable and how I like it to risk again, so feel free to test away, let me know in a month if it's now safe. :)
Have I lost my way?
It's difficult to say as it was a released candidate, Dan. I don't know why, but I just can't see this SP being a problem, especially if you slipstream it (that's what I'll be doing next week). :)
I've not had a problem with SP3 RC2 on my laptop, I wouldn't say it gave any speed or stability improvemnts though. Slipsteaming it should make the rebuild process painless, I have used nlite to it in the past with no real issues.
Same here, Glenn, nLite is great. I'm not expecting any extra stability or speed; I'm just pleased I won't have all the updates to download after a fresh install. :)
For those itching to get their hands on SP3 (I was as I've just reinstalled XP for a friend!) you can download it from the Microsoft site.
http://download.windowsupdate.com/msdownload/update/software/svpk/2008/04/windowsxp-kb936929-sp3-x86-enu_c81472f7eeea2eca421e116cd4c03e2300ebfde4.exe
Although it's not officially released until tomorrow on Windows Update and the Download Centre, someone has leaked the direct link. ;)
That file has given me a bit of trouble, Seb.  Every time I hovered the mouse over it, the PC froze, and when it did come back to life, the file wouldn't delete until I booted into safe mode.  Not sure if it's the file or the PC, but I would advise caution with it.   :-\
That's very strange. I know that hundreds of people, myself icluded, have downloaded and installed it fine. It sounds like it might be one of your security packages wrongly interferring.
SP3 could problems at work, we have several apps that don't run on IE7
Have downloaded without problems, however on 2 pc s so far the installation fails at installing Catalogue files, then warns that windows may no longer run properly
Not a problem saved again by Ghost
When installing service packs its always a good idea to remove your security software and do a chkdsk before and after as well, some security packages have such deep hooks it can mess things up on install sadly. This applies if you can download the package first really, but its the way I went about installing Vista SP1 :)
So, it would generally be safer to wait until the auto update comes along?
Or until lots of other people have installed it first. :)
Quote from: Rik on Apr 29, 2008, 10:08:35
Just
Quote from: Simon on Apr 29, 2008, 09:55:58
just do a scannow Simon, a chkdsk before and after and you should be fine :) I would wait for it to come down the pipe myself but still do those steps
I've just installed SP 3 with no problems on my main PC, just disconnected from the Lan and disabled my security software.  :) :thumb:
Quote from: Sheltieuk on Apr 29, 2008, 11:51:29
best way  :thumb:
I installed on 3 PCs last night without a single issue. I'll be slipstreaming it at the weekend and formatting my PC. :thumb:
