Can a CDROM game in US NTSC format be played on UK pc?
Started by Dont mention Talk Talk !!, Mar 27, 2008, 19:50:23
There is a game called pet vet 3D that I can only source on Ebay from the US, my kids want to play it on my PC , but I know its in NTSC format and not PAL. Would this format render the game unplayable on my PC here in the UK seeing as it is CDROM based ?
James
RA , its not for dvd viewing, its a cd based game for usage on pc.
James
RA-1972
I think they still read the cd the same way ie movie or game !!!! i might be wrong .
RA-1972
madasahatter
Don't think that the CD Rom will have trouble playing the disc -think the problem will be if it can output the signal to your monitor in a way that it can display ie it will possibly be juddery, or black and white etc
Dangerjunkie
#7
There should be no such thing as an "NTSC" or "PAL" PC game. The term should only be relevant to games for consoles as they output video to display on a regular TV. Your PC monitor has a range of resolutions and refresh rates it supports and these should have nothing to do with TV standards at all. I'd be far more worried if I had Vista that it wouldn't work.
As long as it's not mega bucks I would go for it :)
edit: http://www.viva-media.com/product_info.php?products_id=75&osCsid=31052b1643e28ba0b5331dec27dd9748 I see no reason why this shouldn't work in the UK.
esh
Dangerjunkie is right. CDROM have no region protection, and PAL/NTSC is *only* for console games, because the consoles directly output to TV. It does not matter for PC monitors.
