BBC Speed Tester
Started by quandam, Oct 25, 2006, 09:49:28
quandam
Yes, there is a BBC broadband speed tester.
Click on this link: http://www.bbc.co.uk/mediaselector/check/weather/broadband?redirect=fs_index.shtml&bbram=1&nbram=1&bbram=1&prefs=1&weather=1
Hit the 'Test My Connection Speed' at bottom of page and 'Back Button' thereafter to re test.
Can't guarantee the tests accuracy though
Nerval
Interesting one.
Judging by the time it takes, it can only send a few K bytes.
Suppose it's aimed at telling you if you can get decent streaming speeds.
I got 3 Mb and 3.6Mb in quick succession - was 4.6 on the BT speedtester earlier, but that sends a lot more data.
Scott
Speed testing is a real black art, remember you're only as accurate as the number of times you take the test multiplied by the data sent / over time to send so the more times you do the test with more data the more accurate your test will be. However then you have exchange contention to deal with, routing issues on the way to the server, and finally everyone else hammering away at the server doing their speed tests too !
Member of the IDNet Mafia
quandam
Quote from: Scott on Oct 25, 2006, 10:04:11
Blimey Scott! My brain hurts, I think we should go back to bananas, its easier and more fun!!!!!  ;)
