Serious Adobe Flaw Workaround
Started by Gary, Oct 09, 2007, 08:08:04
Posted on the Adobe site for a serious flaw in Adobe Acrobat/Reader, to be honest its a registry fix so it may be worth some people waiting for a patched version, but be warned this hole will compromise your entire machine. Vista users are safe from the issue. http://www.adobe.com/support/security/advisories/apsa07-04.html
Thanks, Gary, a little registry editing to be done then. :(
Quote from: Rik on Oct 09, 2007, 09:37:02
Yep a fun little number as well  :'(
And I use Vista! Good to know it's nice and secure! lol
