2wire 2700HGV anyone using one?
Started by g7pkf, Oct 26, 2007, 17:03:28
g7pkf
Can someone plse help.
trying to connect one of these running sbc firmware and it does not find a dsl signal.
pretty sure i have all correct but can someone pst there settings plse?
excluding dsl username and password of course
I can't see any 2700 users online right now. Lance will probably be in a bit later.
I have a version 2 router but all the details for both are are here http://bt2700hgv.tripod.com/ir1002700HGV.htm
The settings I use (on BT/2wire firmware) are:
ATM Circuit Identifier: VPI:  0   VCI: 38
ATM Encapsulation:  Routed VC-Mux
ATM PVC Search:   Disabled
PPPoA
The required settings should be on the user area of the IDNet website, and how to enter them on Glenn's link.
Hope this helps.
Den
I use the same settings as Lance and they work fine for me.
Mr Music Man.
g7pkf
Sorted..guy sent me another one worked 1st time.
took old 1 apart found crystal not soldered re-soldered now i have 2.
That's a bit of a result then! Maybe sell one on to Rik!
g7pkf
Many of you will be aware of my problems with a long line frequent dissconnections and interferance from virgin trains.
Finally this router has sorted all that out NO DISSCONNECTIONS SINCE IT WENT IN!!
Normally i get 3-10 a day, some may think that quite bad-when i started i was getting 100-200 a day.
all cabling replaced all extensions re-wired properly, several microfilters tried (settled on a solwise faceplate) BT special investigations team got involved, i have tested in excess of 15 adsl routers/modems.
So if you have along line and/or interference from trains etc i would strongly recommend one of these routers (or the 1800 variant).
That's quite a result - presumably we no longer have to refer to you as the Pendolino Dropout? :)
Den
Hey Rik, Looks like another convert to the BT 2700HGV. When are you going to convinced and join us? The HGV fan club will be nearly as big as the Idnet fan club.  ;)
Mr Music Man.
Good to see the 2wire keeping up with its reputation! :)
Woo Hoo, when I first swapped to the 2wire I was on a 1750k profile, that rose to 2500k after a few weeks, today I have taken another look via BT's speedtester, here are the results
IP profile for your line is - 3000 kbps
    DSL connection rate: 448 kbps(UP-STREAM)  3456 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 2765 kbps
Rik, if it can improve my line throughput then I would think it could do similar to yours, get one now  ;D
That's some result, Glenn. I may have plans... ;)
Den
Mr Music Man.
ReDGryphoN
Oh yes,
The 2700HGV is drooltastic..................
but then you know that don't you Rik...............
ReD
MAABOF
BILLION 8800NL USER FTTP
Henry David Thoreau
Quote from: ReDGryphoN on Nov 04, 2007, 11:35:05
I know everything. Except for all the stuff I don't know, of course.  :laugh:
mrapoc
Where/what would you say the deal is now to snap one up? I want a new unlocked one (SBC) - voip not needed for as cheap as possible (student  :laugh:)
My last purchase was pants...was used and cr*p lol
