Microsoft 10 update
Started by Broadback, Sep 15, 2020, 08:14:49
Broadback
The latest update has messed up my machine. everything is so slow, as to be almost useless. So 2 questions please. Can I easily undo the latest update, second can I permanently stop windows  from updating?
My initial advice would be to leave the machine on but unused for a few hours, then reboot.  It might still be processing the updates, which can take some time if you're using the machine all the time.
You can delay Windows updates, but I tried that myself and all it does is prolong the agony as they build up and then there are a load to install at a later date.  Not sure if you can disable them completely, but that wouldn't be a good idea as you would be compromising the security of your machine.
Broadback
Thanks simon, you are quite right, I went off to pick up some parts, came back and it is working fine. Cheers
