a program without equal.
Started by kinmel, Oct 27, 2012, 22:52:25
 ;D ;D
ok own up who's tried it  :D
I've had it running overnight, very stable program with no evidence of any memory leakage. >:D
D-Dan
Doesn't work here. I downloaded it expecting it to do nothing, and it did something :(
Have I lost my way?
Wiped your hard drive?   ;D
D-Dan
Fortunately, I run Linux, so it would be difficult for it to do any damage.
However, I use vim as my text editor, and when I opened it, expecting to see nothing, I say the escape code for a carriage return.
I may have to file a bug report. :)
Have I lost my way?
Quote from: D-Dan on Oct 28, 2012, 17:25:40
That must be a VIM bug,  :think:             there are no one bit escape codes   :D
Looks like a empty file using my OS X editor - 1byte in size no escape codes visible  :)
In fact it has every Hollywood film in it compressed really small. Just follow these 2 easy instructions to decompress it.
1) Hire a camera crew and actors.
2) Refilm every film.
There you go. ;)
D-Dan
Actually, Ben, you are only part right. After close examination it appears to be a multiformat compression, that will decompress to something different depending on the decompression used. e.g.
unrar: the aforementioned Hollywood archive
tar -xzvf: The complete written works of man
tar -xjvf: A highly complex simulation of the entire universe, including weather patterns on all planets
unzip: A to scale model of Russell Brand's head
I'm sure there's more in there ;)
Have I lost my way?
Well, the reality is you cannot compress data. But, you can store a text document and list the instructions "Add universe and time, wait for results*", and it should do everything.
*Universe sold separately.
D-Dan
Shhhhh - don't tell the Motion Picture Expert Group that you can't compress data. They'll be gutted to learn that they've wasted 40 years.
Have I lost my way?
Well, they did not. They never compressed it, they did however remove some of the unnecessary stuff and some of the surplus. Wish they'd do that with the majority of "comedies" and "action flicks" and "romances" too!  :laugh:
