Telecom NZ 2701 Help
Started by d0ct0rfill, Dec 26, 2011, 02:31:03
d0ct0rfill
Hey guys, seasons greetings and all the rest.
Just been pulling my hair out over this one, I have a Telecom NZ 2701 Business Hub modem/router and (as we all know) it is locked only to Telecom NZ ISP (as changing the settings says that it isn't allowed). I have done some pretty serious scouring of the net, looking for ways to flash the firmware on this puppy.
On the standard router menu (192.168.1.254) there is no 'management' or 'tech' area (probably hidden), and I have tried several different methods I found mentioned (home/mdc etc..) to no avail.
Can anyone point me in the right direction for this? Does anyone know of the address for the hidden management console (if there is one)?
Thanks for your time,
Hope everyone is having a good Christmas :)
Phil
RogerP
Hi Phil
Have a look at this link it may throw you a life line
http://bt2700hgv.tripod.com/ir1002700HGV.htm
Rogerp
Hi Phil and welcome to the forum. :welc: :karma:
FritzBox
Would imagine your only hope would be the QWest firmware, but haven't seen anyone have any success with a 2701. I don't have one to try it on I'm afraid
Polchraine
Quote from: d0ct0rfill on Dec 26, 2011, 02:31:03
Phil
Is it a 2701 or a 2700 ?
Does it have a large button on the front and does it have a WAN port?
The 2700 actually has internal part number which start 2701 which can confuse - teh 2701 also has hardware part numbers of te same form.
Go to:    http://home/xslt?PAGE=C_0_0     or   http://home/xslt?PAGE=A07  (depending on version) and there is a line
Hardware Version:    2701-100630-009   or
Hardware Version:    2701-100589-005   or
Hardware Version:    2701-100588-005
Can you say which it is.
