Windows 7 File Save As Hangs
Started by nickmoul, Feb 10, 2011, 20:53:48
nickmoul
If anyone has any ideas on this one. For over a week whenever I use any Office 2010 application and come to Save as... the dialog box hangs as well as the application. Inevitably I've lost work. In the end I uninstalled Office 2010 and reinstalled Office 2003, which has - I think - sorted it. I found Office 2010 annoying until I installed the 2003 menu application, but it had worked really well for some 2  months.
Thanks in advance.
Kindest regards
Nick
esh
How long did you wait? I suspect the previously used directory in Office was on a network drive it is trying to re-establish, but it will usually give up after a few minutes.
Hi Nick, welcome to the forum. :welc: :karma:
