spare parts....
Started by Baz, Aug 18, 2010, 21:14:19
...for a laptop.need a new power supply for my wifes lappy.Any good places at a reasonable price
thanks
also would it be best to get a genuine toshiba one or one of the generic ones
I've in the past purchased 2 Toshiba laptop power supplies from 'generic' sources and they've been ok,can't remember where though.
Quote from: Glenn on Aug 18, 2010, 21:48:37
What model laptop?
its a satellite pro L300  Glenn
That's a good price Glenn :thumb:
thanks that looks good.I noticed some on Ebay state you have to buy a plug seperately.Have to be careful on the bay  :D
oooo just noticed theres £4.50 shipping on that
If you already have a PSU, then you shouldn't need a power cable, assuming it is the same type of connection..
