eTEC PTI-845G
Started by neocr0n, Feb 14, 2007, 21:28:20
neocr0n
Sorry not sure if this is the right place.
Just wanted to know if anyone uses one?  Are they easy to get along with?
http://www.linuxadsl.co.uk/index.php?page=shop.product_details&flypage=shop.flypage&product_id=23&category_id=6&option=com_phpshop&Itemid=6
Just looks a real good price for a wireless modem router, netgear etc charge a fortune these days.
Play Counter-Strike 1.6 online 6 years and counting. :(
maxping
siege2
#2
Well I got my first Router from www.solwise.co.uk years ago" PS I'am no where near anough old BYW"
they also do billion routers
Home SuperMax "BT IPStream Max Premium"
_____________Downstream____Upstream
Data rate...........8128.....................832
Noise margin.....8.1  ......................12.0
Output power....7.8.......................12.5
Attenuation........4.0.......................2.0
Quote from: maxping on Feb 14, 2007, 22:15:05
but i douby you will find anyone using one here.
Would that be as in douby, douby, do, Max? ;) :out:
knock
£40 seems a fair price but i douby you will find anyone using one here.
I use one of these  and  rate it - http://www.ciao.co.uk/click.php?oid=2114866&cid=5190366&url=http%3A%2F%2Fwww.ebuyer.com%2Fct.html%3Fct%3DeJwrMDS0MLIwsi42NrJOMTIwMDcwMjS2zjEEAElJBcA%253D%26_LOC%3DUK
After my raving about the vanilla 5200 in the tips & tweaks section I was just going to suggest looking for a 5200g with the caveat that I didn't know anything about the wireless side of it, price seems a bit steep though try here... http://www.broadbandstuff.co.uk/product_info.php?products_id=794
maxping
Cumbrian for Doubt  ;)
neocr0n
Haha thanks guys, I think I'll purchase that one.
