UK 2700HGV in New Zealand
Started by EvilPC, Jun 02, 2010, 16:09:00
EvilPC
All being well I'm moving to New Zealand soon :D
Will my UK 2700HGV work their ??
Absolutely no idea, tbh. I don't know what standards they use there. Hope you get there though. :)
Take a look at this, you should be OK, though you'll probably need to get a new power brick.
http://www.techie.net.nz/adsl/setup.html
Quote from: EvilPC on Jun 02, 2010, 16:09:00
Yes it will work fine, the 2700 is used by Telecom
I think Australia and New Zealand have very similar system to ours except everything is  upside down so to speak
MisterW
#5
Quotethough you'll probably need to get a new power brick
I thought NZ was 220-240v 50hz similar to the UK. I suspect a NZ to UK plug adaptor is gona be cheaper than a new power brick for a 2700!.
New Zealand's Ebay sells the 2 wire routers and power supplies too  ;D
EvilPC
Thanks.
In that case it can go with me.. :)
Just need to sell my other 2700 which has v5 firmware.
Quote from: EvilPC on Jun 03, 2010, 21:00:58
Thanks.
Looking at the prices on Ebay NZ, it might be worth taking a few with you and selling them once you're settled  ;D
