SNR all over the place
Started by coreservers, Dec 12, 2009, 10:09:16
coreservers
Fitted this new router to repalce teh dying and eventually dead netgear. same model but since installing the SNR has been up and down wuite a bit.
before the change my SNR was a steady 6 since last saturday it's been rising steadily to what you see below today
Connection Speed 6146 kbps 1038 kbps
Line Attenuation 36 db 9 db
Noise Margin 15 db 5 db
I have it in the test socket. my throughput has fallen from 7mb to 4.5 now as well
BT tests keep failing!
odd since chaging the router the connection has become unstable
If it's in the test socket then it's either a line fault or a bad router. Check with support.
coreservers
now resyncing every 4 or 5 minutes. can se the router fine and silent line test fine I'm suspecting bt's marvellous exchange work . lets facce it teh have a previous record of poor workmanship with me!  :bawl:
coreservers
im guessiong BT just did some work at my exchange
suddenly I'm sync'edc a meg faster and SNR dropped away to 8
ADSL Link Downstream Upstream
Connection Speed 7494 kbps 1070 kbps
Line Attenuation 37 db 9.5 db
Noise Margin 9 db 6 db
It's a distinct possibility, they seem to be kicking the tyres a lot recently.
