test router stats
Started by coreservers, Aug 01, 2009, 12:18:55
It should, they should. :(
coreservers
well they found a fault on my exchange and we lost the phone for most of the day, all back agai, and guess what...............
    Your DSL connection rate: 5966 kbps(DOWN-STREAM),  1038 kbps(UP-STREAM)
    Actual IP throughput achieved during the test was - 3703 kbps
Connection Speed 5966 kbps 1038 kbps
Line Attenuation 43.5 db 21.5 db
Noise Margin 15.0 db 8.7 db
They've raised the SNR to 15 and lowered my profile again from 5500 where it's been for 3 days to 4000.
So they fix hte phone and knacker the broadband again
IDNet may be able to get the NM reset manually in the circumstances.
