Kaspersky 2010
Started by Den, Jul 20, 2009, 22:54:57
Den
Updated on line to Kaspersky security suite 2010 today but it will not let me run the firewall. Thats not such a problem as I use the one on my router but it worked OK on 2009. The only thing I can think of is the fact that Vista on this machine rejects the SP2 update and maybe Kaspersky 2010 requires it.  :dunno:
Mr Music Man.
Quote from: Den on Jul 20, 2009, 22:54:57
Did you do an install over the top? 2010 is a bit buggy but does not require SP2. I tried it and for me it slowed down surfing, and has a memory leak as well that Kaspersky are aware of, they are working on critical fix 1 which is in beta, the best way to upgrade is to do a clean install even though it says you can update over the top the recommendation is to not do that. For now I'm sticking with the last version till they get the issues sorted out, also the PDM module is a little bit keylogger happy reporting kernal patches with no pid, so I would hold off myself, Just my view. 2010 uses the same engine as the 2009 version, also there is a constant rootkit scan in the background that slows some computers to a crawl, this can not be turned off or scheduled, you will see the K pulsing when it does it, the forum has people with similar issues like Nod version 4 it seems it was rushed a bit and scans take a lot lot longer which is a step backwards really.
I haven't updated our Windows machines yet - I like 2009 and think I'll hang on for a while.
Quote from: Sebby on Jul 21, 2009, 00:31:58
I would stay with it Sebby untill 2010 is fixed, even though its a release it feels like a beta and many people have gone back  :sigh: crank another notch in the death of the PC and a plus for a mac
Den
Just uninstalled 2010 and reinstalled from scratch and all seems OK now. Must admit I like the feel of it (and Kaspersky isn't bad either)  ;D
Mr Music Man.
Good luck with it, Den.  :)
Quote from: Den on Jul 22, 2009, 17:21:03
Did you ever use 2009, Den? I'm interested to hear how it compares. I haven't bothered to update our Windows machines as 2009 is running so nicely.
Den
Yes it was 2009 I uninstalled. 2010 seems to run very smoothly and I like the interface. Programs such as Outlook 2007 seem to operate faster but it's early days yet.
Mr Music Man.
Quote from: Den on Jul 23, 2009, 07:39:02
new CF1 is out den,
FIXES
Problem with system instability after long period of program operation has been fixed.
Error causing BSOD while updating the emulator driver has been fixed.
Pop-up message in the URL checking module has been fixed (for the Spanish version).
Problem with pausing the scan task while third party programs are running in full-screen mode has been fixed.
Problem with the update task freezing at system startup has been fixed.
Vulnerability that allowed disabling of computer protection using an external script has been eliminated.
Driver crash in rare cases while processing a write operation has been fixed.
Crash while processing data incompliant with the protocol of Mail.Ru Agent has been fixed.
MAIN KNOWN ISSUES
If a threat in OLE object is detected, the application does not suggest user to perform disinfection. Possible actions in this case – place file to quarantine or delete it.
Web Anti-Virus does not notify user about the downloaded files.
Problems with display of some files in special defragmentation software - PageDefrag are possible.
In some cases the "^" key on the virtual keyboard stays pressed. To solve this problem, right-click this key with a mouse.
Complex filtering works incorrectly in some report windows.
When the option of logging file system events to application report is enabled, noticeable slowdowns are possible during installation, if Kaspersky Anti-Virus 2010 is being installed over the previous version.
During Kaspersky Anti-Virus uninstallation registry keys linked to shell extension are not removed.
Still to many issues with it and it not detecting things for my liking the first version had to be updated as it missed loads of malware the old version found  ::), its buggy and rushed just as Nod V 4 was its all about getting next years product out not making a product work.  :shake: I am thinking about moving away from it completely.
I'll wait until you give me the okay, Gary. :)
Quote from: Sebby on Jul 23, 2009, 13:08:40
Will do Sebby, its not happy with FF either so I'll keep you posted, for now 2009 works great, and as said its the same AV engine anyway.  :thumb:
